Please Help - Here's everything I have --
Its a 1995 Blazer engine code W. No start after warm up except with starting fluid. I have a new fuel pump and filter and carries 62 psi at starting and runs regularly at about 58 to 59 psi and doesn't drop off after warm up. Fuel pressure regulator working correctly, new coil and ignition module (the one on the side of the coil on a heat sink) and both the old ones were faulty. Was jerking and hesitating until I cleaned the EGR valve today with with Seafoam and replaced gasket. But I still have this problem that the engine starts running eratically and then dies rather quickly afterward. It will only start up right after that with starting fluid. And I'm pretty sure it still does the same even when cold overnight. Please no guessing, I checked the codes with a OBD II scanner and had a P1351. If this is some kind of common problem with thes 95's, please let me know.
Have you taken a look through this thread: https://blazerforum.com/forum/showth...ighlight=p1351
It will explain the code your truck is throwing. It's a good place to start. |
Here are the charts for this code on your truck:
http://i11.photobucket.com/albums/a1...1_diag1of1.gifhttp://i11.photobucket.com/albums/a1..._P1351_sch.gif Check for: - Poor connection or damaged harness - Inspect the PCM harness connectors for backed out terminals "GR9" and "BK18", improper mating, broken locks, improperly formed or damaged terminals, poor terminal to wire connection and damaged harness. - Intermittent test - If connections and harness check OK, monitor a digital volt meter connected between PCM terminals "GR9" and "BK19" while moving related connectors and wiring harnesses. If the failure is induced, the voltage reading will change. This may help isolate the location of the malfunction. GR9 is the 9th pin on the gray connector to the PCM. BK19 is the 19th pin on the black connector to the PCM. I'll leave the guessing up to you. Seriously... Why would you say such a thing? That just inspires people to stop and take the time to help you... |
Sorry, I didn't mean any harm by the no guessing. I have read some other replies to other threads with similar problems and I was just trying to eliminate too many replies that have 'suggestions' on what to try. I work about 10 to 12 hours a day and lately about 3 to 5 more just on getting this Blazer back on the road again and running correctly. The problems that this thing is capable of producing or already has makes any of the three Buick Grand Nationals I used to own and race seem like a tropical vacation in middle of a Midwestern Winter. I bought this Blazer cheap for my winter transportation. I have owned many others over the years ranging from mid 70's K5's to 93 & 94 Full Size and a few other S10 Blazers. This one has been the most tempermental. I will hopefully have the time tomorrow to review and test according to the charts for the P1351 code. Thank You very much.
Ahh, The K5 days. Carburetors...gosh how I miss the simplicity and reliability of no Sensors.
Actually, most of my cars are from that '70's era. They just keep running and if not, they let you know they are getting sick, they don't just die. |
I did all the testing (for the P1351 code) and......
... after it is shut off and don't start. It has no voltage at the 'B' terminal for the Ign. Cont. Mod. plug, but has the good continuity between the GR9 and that same B terminal. In other words no 1 to 4 volts coming out of the computer while cranking the starter. Does these computers have the quad drivers for the CPI injection? Is it possible that the injector is causing the computer to warm up and quit?
Sounds like you have narrowed it down to the faulty PCM connector or faulty PCM.
Maybe a Crank positioning sensor that is failing from heat and shutting down the module.
Do both types of ignition systems on...........
......on these this year have a CPS?. Or a pickup coil? I'm trying to finish this thing up today later and I'm trying to get what I need. So far: fuel pump was low on pressure - REPLACED with new. Ignition Control Module tested faulty - REPLACED with new. Igintion coil had no secondary resistance only after running it about 5 to 10 minutes - REPLACED with new.Tested everything according to the P1351 code fault and have no cranking voltage at the PCM terminal GR9 (goes to the white wire terminal or 'B') afte it runs and then dies or after unning for about 10 minutes and shut off and then tried to restart.
I do not have anymore money left to buy parts that Might be the problem. Is there any more tests that can be done to determine what is the Cause of this? If I had about another $1000 to burn I would just replace the remain suspected items - CPI injector, PCM, pick up coil or CPS. And while I'm spending money that I don't have a throttle position sensor and a new EGR valve too. |
As of tonight...
It now has a new PCM and a new CPS. Any smart or experienced people out there want to try to explain to me why it doesn't start when warm on its own with 62 psi of fuel pressure, no voltage at that white terminal (GR9) or the white one on the ICM plug when its turning over, but it fires right up with starting fluid. :icon_hunter:
