you better watch out cause mine did the samething was making a hiss noise brakes felt a little funny then i got home went to leave a little later and my brake booster was done my truck would stall, and i picked up my brake booster for 100 all you have to do is take the old one out bring it to autozone or something & buy your new one. it kind of a pain in the *** to get 3 of the 4 nuts off but saves money haha!
YES, Your booster WILL GO BAD! I had this same problem, eventually stalling the vehicle when the brake is applied. I replaced with a new one, and there was NO HISS. The hiss is a sign it is going bad. If it starts to effect engine speed, you have days at best.
Originally Posted by Chuk Rhodes
(Post 352216)
Glad you found out it is okay. I was going to suggest you look at the large vacuum line going from the intake manifold to the brake booster. If that large vacuum hose is bad, it will cause a 'hiss'. It is subjected to a lot of twisting and flexing because the rubber hose goes from the shaking engine to the rigidly mounted Booster on the fire wall. It seems they always split on the other side of the hose that you cannot see. They are relatively inexpensive and easy to replace.
