Po452
Po452
SOOOOO this is the code...
Evapo leak? or sensor problem is what mr autozone said...
Where do I start?
Also my rear suspension is creaking like an old person!!! could that just be bushings?
Where do I start?
Just realized that... Guy at Autozone, said it would need new lines, while second guy at different autozone said it could be caused by "overfilling" my tank, because I mentioned I top it off everytime.....
He also noted that its a 46 dollar sensor and that he couldnt clear the code... But he then coughed *remove the ground* if its bothering that much...
Thanks again, I will be checking this out, and he also mentioned if there was a problem that I would start smelling gas...
KYLE SAVES THE DAY!!! AGAIN!!!
Trouble Code: P0452 (4.3L V6 VIN W Auto)
Fuel Tank Pressure Sensor Circuit Low Voltage
Number of Trips to Set Code: 1
The ignition switch is in the RUN position.
Possible Causes:
- CCM Details
Possible Causes:
- 1. Inspect the Control Module harness connectors for the following conditions:
- Improper mating
- Broken locks
- Improperly formed
- Damaged terminals
This link has complete flow charts for all DTC's:
https://blazerforum.com/forum/tech-a...agnosis-26408/
