Po452
SOOOOO this is the code...
Evapo leak? or sensor problem is what mr autozone said... Where do I start? Also my rear suspension is creaking like an old person!!! could that just be bushings? |
THANK YOU
I searched PO452 and found nothing |
Try a 0 (zero) instead of an 'O'. :icon_wink:
Just realized that... Guy at Autozone, said it would need new lines, while second guy at different autozone said it could be caused by "overfilling" my tank, because I mentioned I top it off everytime.....
He also noted that its a 46 dollar sensor and that he couldnt clear the code... But he then coughed *remove the ground* if its bothering that much... Thanks again, I will be checking this out, and he also mentioned if there was a problem that I would start smelling gas... KYLE SAVES THE DAY!!! AGAIN!!! |
I also have a p0452 on my 99 blazer. Were you able to resolve the issue?
Trouble Code: P0452 (4.3L V6 VIN W Auto)
Fuel Tank Pressure Sensor Circuit Low Voltage Number of Trips to Set Code: 1
The ignition switch is in the RUN position. Possible Causes:
This link has complete flow charts for all DTC's:
https://blazerforum.com/forum/tech-a...agnosis-26408/ |
