RE: poping noise when getting in truck
After I installed new shocks, I had a similar problem. It ended up being the shock mounting bolts. The steel liner to the bushings on the shocks were not as wide as the original shocks. So the bolts needed to be tightened much tighter to pull the mounting tabs in against the sleeve in the new shocks. Drove me nuts.
ill try that but how long after you put the new shocks in did it make the noise? like i said it had new shocks on the truck when i bought it right about a year ago.
ORIGINAL: dBsound But, I have a cousin that will change two for a 30 pack of PBR! |
Originally Posted by 95LS
(Post 202879)
ive never had to change cv shafts. the only ones i come across online is cardone/A1 i assume theres not a lot of diffrence between cv shafts so these should be good enough ?
