-   -   Popping noise when turning 97 blazer new cv drive axles (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/popping-noise-when-turning-97-blazer-new-cv-drive-axles-45187/)
dj00140 06-01-2010 01:42 AM
Ok I had a friend replace my cv drive axles in my 97 2-dr blazer 4wd. And its still making a popping noise when turning and turning in reverse. Is it possible he just didn't grease them when he put them in? he said I need a lower ball joint on the drivers side also. Was he supposed to grease them when he put them in? any help is appreciated.
swartlkk 06-01-2010 06:27 AM
If the whole CV axle was replaced on either side, there would be no greasing involved.
Where did you get the parts from? Were they used or new/reman units?
As a diagnostic step, you could try removing the CV axles completely and turning to see if the noise is still present. This would be a test ONLY. The truck should not be driven except a very short distance at relatively low speeds to test it. Damage to the wheel bearing assemblies could result from prolonged use without the front driveshafts installed
dj00140 06-01-2010 12:08 PM
I dont have the means to remove it again... could it just be the ball joints?
