Power door lock relay?
Old Mar 31, 2009 | 05:35 PM
bodarblazer's Avatar
bodarblazer is on a distinguished road
Default Power door lock relay?
Where would this located in a 99 blazer ls 4 door? i can hear the clicking of whatever dont work i cant locate it though it sounds like its in the behind the cluster guage. Couldnt be in that bad of a spot or is it? if it is then that is super gay, lol. i can maually lock all my doors except the rear hatch? my stereo will get jacked if i dont fix this by tonight. Ill have to pull everything out till its fixed .
Old Mar 31, 2009 | 07:30 PM
Open the driver door. Remove the instrument panel trim cover off of the end of the dash. Read the label inside to identify the lock relay.
Old Mar 31, 2009 | 08:04 PM
Meaning the cluster guage trim? thank you very much for your help.
Old Mar 31, 2009 | 08:19 PM
No. Take a look at the very end of the dash, what is parallel with the side of the truck. You can only see this portion of the dash with the door open. There will be a small cover that you can remove.
Old Mar 31, 2009 | 08:20 PM
96chevblazer's Avatar
No, No I just replaced my lock relay yesterday. If you open up your pas. door you look under the dash. Remove the first plastic covering on the bottom. Then there Is a little lock relay that looks like a small black box. When you hit the lock button it should click.
Old Mar 31, 2009 | 08:30 PM
A 96 is different than a 99... The information I provided came straight from the GM SI DVD.
Old Mar 31, 2009 | 09:27 PM
ok well i looked where you directed me and thats the fuse box. no relay in there. although the sound does come from that direction. i will scope out the other one here in a few minutes.... again thank you for your help guys.
Old Apr 1, 2009 | 03:09 PM
The diagrams I show are kind of odd... Not the typical display. And of course, now I cannot find it. If it is not accessible from the side of the dash like the illustration I had previously found detailed, it is accessible from underneath. From my information, it is definitely on the driver side of the dash, not on the passenger side like the early 2nd gens.
sporty982000
Aug 24, 2014 01:05 PM
Coleon
Jan 27, 2012 04:44 PM
dardamar
Oct 8, 2008 02:03 AM
Fat_Phil
Sep 29, 2008 04:57 PM
a156
Aug 26, 2007 08:52 PM
