Power steering high pressure leaking- how to replace
The power steering line the high pressure side is leaking. I want to replace but when I look at it I didnt see how I could access the back of the pump to remove the line. Can I do this without removing a bunch of stuff? Or do I need to take the pump off?
I have been searching all over for a how-to. |
2wd or 4x4? I know on my 2wd i was able to access it from underneath with an adjustable wrench, a stubby wrench would be even better(i think it was 13 or 15mm). To get at the line on the steering box side the air intake has to be removed(piece of cake), then its easier to go at it from the side from the wheel well. Not much has to be Removed, just snake your arm up in there and have some patience, you can get them both off.
Thanks for the reply. I was able to get it. not easy with 4x4 but do able.
| All times are GMT -5. The time now is 08:06 PM. |
