Power Windows + Water = big mistake
Ok...so this is my problem. I got into my 2000 blazer one day and my phone charger was sitting in a large cup of water. Since electricity was running through all night I figured there was some sort of electrical problems which of course there is. I checked both fuse boxes nothing appears to be blown. All four windows do not work with the exception of the passenger side will go down if you give it a little push. Also, when you push any of the window buttons it makes the lights flash on the other window buttons in the car so it appears that some electrical connection is going on but i have no idea. Any suggestions? is this a self fix or take to dealership?
RE: Power Windows + Water = big mistake
I'm not sure if i'm following. Your phone charger some how ended up in a cup of water, it was plugged in, and since then your windows don't work? If you don't know much about electronics, it's better to let a professional handle it, that way there's no chance it will get messed up, and if it does, it's their fault. Dealers are the best bet.
