Problems with Truck!!!!!!
Old Feb 21, 2009 | 12:18 AM
chrisjanicki01's Avatar
chrisjanicki01 is an unknown quantity at this point
Default Problems with Truck!!!!!!
Behind the dash board, it sounds like a weird whining grinding noise. I installed new wheel hub bearings. Not the problem, i got responses from 5 diff people. IDK WHAT THE PROBLEM IS!! DOES ANYONE ELSE HAVE OR HAVE HAD THIS PROBLEM AND IF SO, WHAT DID U DO ABOUT IT AND/OR WHAT IS IT!!
2000 CHEVROLET BLAZER
4.3 LITRE 4 DOOR 4WD.
98,000 MILES
Old Feb 21, 2009 | 04:27 PM
Default RE: Problems with Truck!!!!!!
How loud is this noise? Does it vary with engine speed? Who told you this was the wheel bearing assembly and why?
*Moving to 2nd Gen Tech* - Gen Chat is not the place for tech questions. Now turn off the damn CAPS key. We do not need to be yelled at!
Old Feb 21, 2009 | 05:49 PM
ChevyRules's Avatar
ChevyRules is an unknown quantity at this point
If it stops after pressing the gas a lil bit and its relatively quiet, than I have the same noise. I have no idea what it is though :/
Old Feb 21, 2009 | 07:31 PM
flyinquack's Avatar
flyinquack is an unknown quantity at this point
ORIGINAL: ChevyRules
ditto. i would also like to know what it is and if its something i should worry about.
Old Feb 22, 2009 | 09:03 PM
RonJon's Avatar
RonJon is an unknown quantity at this point
Sounds like a heater blower motor. Does the noise change with fan speeds?
Old Apr 4, 2010 | 09:40 AM
wood0470's Avatar
wood0470 is on a distinguished road
i have the same exact problem with my 96 blazer 4x4 it sounds like its coming from the dash but im pretty sure its not the blower motor..it tends to go away when i apply the gas, but does not vary with the blower motor...some please help..did you ever find out what it was. id like to know before i pull it all apart
Old Apr 4, 2010 | 09:56 AM
DaveC's Avatar
DaveC is on a distinguished road
believe it or not it is most likely your pcv valve that is causeing this noise. i had the same issue and it bugged me forever....as did londonmazda with his 96 he figured it out by accident while reaching around the motor he touched the vacum line and the noise stopped, we replaced the pcv and it went away i tried it and it fixed mine too. go under the hood with the engine running and reach down to the pcv valve and feel it, it is probably vibrating like mad... replace for 3 bucks and i bet the noise goes away.
bobby099
Dec 22, 2018 09:41 PM
bigdaddykane93
Jan 27, 2016 11:35 PM
er0ck273
Jul 31, 2015 04:10 PM
upblazer95
Apr 4, 2009 08:27 PM
chrisjanicki01
Feb 21, 2009 04:27 PM
