Quick help needed! Secuirty breach!
My blazer will not start at all, I read the code and it says that secuirty wont let fuel pump activate..
Anyone know how to disable this?
Disconnect the battery?
Edit heres the code
P1260 Theft Detected - Engine Disabled. but it said fuel pump disabled
Edit heres the code
RE: Quick help needed! Secuirty breach!
Are you sure it was P1260???
P1260 - Fuel Pump Speed Relay Control Circuit
But then again, I found this through OBDII.com (GM specific), but I do not think this is a code that applies to the S-series as there is no fuel pump speed relay in the s-series trucks.
Coupled with your other problem, Just died...., this may be the beginning of an ignition switch failure.
it had a 1 and a 6 in it.....
The message deff said Security threat fuel pump disabled...
should I just have it towed to my dealer tomorrow mourning and have him take a good look over?
what year blazer???
My '00 had security issues. Fortunately it was under warrenty, and the dealer replaced the ignition switch. It would start sometimes, and not others, when it didn't start the security light would come on.
thats what mine does!!! wow I could never find anyone that had the same issue..woo doggy. anyhow, would you classify the ignition switch as a DIY possibility or should I just pay for that one?
ORIGINAL: hillbillyinOhio
what year blazer???
what year blazer???
My bad, its in my sig now....
I still have warrenty on mine so Ill just throw at my dealer....
brooklynRick
07-08-2011 05:14 PM
igot10pinitis
01-19-2008 10:42 PM
