Quick Question - How to disconnect vapor purge solenoid hose?
Ok in this picture
http://img3.imageshack.us/img3/1235/dmap.png It shows the evap purge solenoid hose it is circled by the p, on my 97 2dr blazer 4x4 There is a weird clip that looks like it goes sideways through the hose and holds in the solenoid, any idea how to get it out? Thanks. |
*Moving to 2nd Gen Tech* - Please read the forum descriptions and choose the most appropriate forum for your question. Technical questions are not appropriate for General Chat.
The grey/white plastic clip is an c-clip. You need a small right angle pick to lift the clip out of the end of the evap line. Be careful as they like to go flying when you get them out... |
1 Attachment(s)
Thanks.
Thats weird, cause I cant see where there is an opening on the clip like the gap on the "C" It appears I would have to rotate it to slide it out as both sides of the plastic are solid there is no opening in them if that makes sense, I included a pic to show how it has to be in there if it is a c-clip, thanks for your help I really cant afford to ruin this. Sorry about the bad pic but this hopefully explains it, |
That's strange... It looks like somehow the clip rotated in there... Should be able to pick at the clip and get it to rotate, then pull it out the side.
| All times are GMT -5. The time now is 12:04 PM. |
