any one know how to get starter back on 97 chevy blazier
Im not trying to sound smart but the way it came out? please explain your issue better.
:icon_hunter::icon_hunter:
Originally Posted by Brenda Brumley
(Post 556574)
I just finished removing the starter on my 2000 blazer 4 door 4x4. It was original and has lasted over 200,000km.
I found the process relatively straightforward after reading this topic. It took about an hour moving slowly. Thanks everyone for the help. The problem I had was that the starter failed to make any noise on ignition. Diagnosing the problem
Removing the starter
Piece of cake. Now just have to buy a replacement tomorrow and reinstall. |
very helpfull info, got the old starter out in 1/2 hour
Took me about an hour total to remove and install mine,I loosed up the the y pipe on the exhaust.When ever it warms up I`ll be doing it again cause I have tighten down a wire going to the starter cylinoid:icon_doh:
Just found my starter bad due to corroded wire from solenoid to starter motor. It actually fell apart. Im in the middle of doing a timing cover/ oil pan gasket and have axle removed so I actually swung right side axle tube bracket out of way to get it out.
Any suggestions on a replacement starter? |
Originally Posted by TMM217
(Post 656770)
Any suggestions on a replacement starter? If it's the original starter, I would see if a local shop can rebuild it for you. We have had poor luck with replacement starters. The nose piece of most seem to be off just a bit requiring major shimming. Our local electrical specialist can usually rebuild most starters around $60-70. |
This is a very old topic and it would have been best to start a new one. But since that was not done.
I have not had an issue with a replacement starter. Getting one rebuilt will take more time than it is worth. I replaced the starter in my Jimmy with one from Orielly over 3 years ago and have not had an issue since. |
Well I bought a DB Electrical new starter from Amazon. Install went well and so far so good. Time will tell.
How do you know if shimming is required? |
