-   -   Radiator Lower Support / Mount / Isolator / Bushing Help (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/radiator-lower-support-mount-isolator-bushing-help-74749/)
grantolson87 10-24-2012 01:45 PM
Hello All,
1999 Blazer 4WD
I had a crack in my radiator so I went to replace it and when I pulled it out there are two isolators/ mounts/ bushings that are rubber and have a small hole that accepts the tab from the bottom of the radiator.
The rubber isolators are shot, I cant even keep the one in its place. My issue is that I cannot find these anywhere. Are they the same as a body mount? Does anybody have a part number for these? I checked out LMC as well as my usual online research to no avail.
I appreciate any help you can give a Blazer newbie (lots of S10's but this is my first Blazer.)
Thanks, Grant.
dbelcourt 11-30-2019 05:18 PM
I know the thread is old but in case someone else ever does a search.
When I replaced the radiator on my 1995, the rubber mount bushing were gone. The parts store wanted $25 a piece to special order them. Although I've seen some online for $5, I needed to finish the job ASAP.
I made my owe using rubber freeze plugs. I think it cost me $12 for two. I drilled out the center so the radiator bottom pin fit. Then I turned down the bottom OD to fit inside the hole of the metal.
I'm attaching pics of a plus and the mount.
https://cimg4.ibsrv.net/gimg/blazerf...bd72ce6a13.jpg
https://cimg3.ibsrv.net/gimg/blazerf...92cec0abb1.jpg
