Radiator n antifreezer flush
I have dex-cool antifreezer n my radiator but i need to change the radiator because one of the plastic tank is craked n the antifreezer was leaking so is ok if I change from orange to green antifreezer
Yes, but you need to flush all the Dexcool out of the entire system including the engine block.
What I need to do to flush the antifreezer from the engine block. I flush it before n I take the thermostat out the engine and run water through the upper radiator hose. these is the same way to flush it out the engine block, if so thanks for you help!!!
Originally Posted by lucas30
(Post 464858)
Thanks for the input Dobyken I just dome with my 12 hours shift work so relax for little bit n star working in the truck let you know how I ended...
Thanks for all the support Dobyken my blazer is running with new radiator n green anti freeze with the temp gauge in 210 degrees so is the ok. thank you so much for you help..
(Post 465303)
