Radio and button lights
RE: Radio and button lights
You'll have to take your switch panel off to get to them...
And those lights in your A/C buttons are soldered directly to the circuit board... I think, I don't have those buttons, so I can only assume they're the same as my rear defrost button.
ORIGINAL: drperry
The LED that notes when the "A/C is on" is working - it's the lamp that illuminates/glows behind the switch that's not illuminating nuttin. How do you get into it to change it out?
I'm leaving the radio alone - for now... I can feel in the dark for the buttons.
HINT: I would set the parking brake, chock the wheels, parking on flat. Then tilt the wheel all the way down and put it in gear 1 to move the dash surround around the gearshifter and steering wheel.
Once this is done just remove the two screws and push in on the springy clips that hold the HVAC controls (Heating Ventilation Air Conditioning) in place. Then remove the wiring and take the back panel off by removing all screws except the ones holding the ***** in place. Also you will need to pull on the ***** from the front to remove them. Then you should have access to the circuit board and light and then you can see if you really want to fix if from there.
Hope this helps.
Darn good step-by-step writeup there Lenny - thank you VERY much -- perhaps it could go in the "how-to" section
[align=left] [/align]
I had the HVAC lights in my Jetta go out once. A hard smack to the panel fixed that.
Thanks for the compliments though.
762mm
15
08-28-2023 03:32 PM
Flyfishen
06-18-2019 11:22 AM
philmatschke
10-06-2010 03:47 PM
180_nissan
12-15-2007 08:06 PM
