rattle in front end on rough roads
1998 jimmy 245000 miles just finished major suspension ovehaul
New ball joints tie rods inner and outer wheel bearings front u joints shocks new cv axles up front i had the rattle before all the work front right rattles pretty loud on rough roads other than that alls well anyone have any ideas i have checked the sway bar all seams good |
Check the bushings that go between the frame and the crossmember that holds the rear end of your torsion bars, under front seat area but sometimes sounds like under front end, my ZR2 had bad bushings.
One thing iv learned about having a blazer is EVERYTHING rattles
Originally Posted by 1sexyblzr
(Post 339516)
http://i578.photobucket.com/albums/s...appy0045-1.gif |
my front bumper rattles against my fenders on washboard roads. If it isn't one thing, it's always another.
Originally Posted by 99blklt4wd
(Post 339522)
On mine my calipers rattle on the slide bolts. Sounds really bad but it's not a problem. Does your problem go away when you brake?
I have a 2003 Blazer and a 2000 Jimmy and they rattle and squeak like no end. Damn good vehicles if you can take the squeaks and rattles.
My 2003 Blazer LS has a rattle that seems to be coming from behind the dash near the blower motor maybe. Had 2 different mechanics look at it as well as myself pulling everything apart, but just can't seem to find what is causing it. Doesn't seem to be anything important, so just turn up the music and wait for whatever it is to fail :D
It has been there for almost 2 years now. |
CTY I am with you I have squeaks and rattles all over the place (Doors dash etc) I agree drive it until you have a problem.
| All times are GMT -5. The time now is 05:03 AM. |
