-   -   Rattle on Right side of Blazer when going over bumps!! (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/rattle-right-side-blazer-when-going-over-bumps-73249/)
lionel2 08-25-2012 05:28 AM
Hello all, My 2000 blazer is making a rattling sound from the right side of car when going over bumps. Any idea what might be loose or the problem?? I checked the exhaust pipes, looks good there. Sound like a piece of metal flapping around. SHould be easy to spot, but I see nothing out of the ordinary.
aa21830 08-25-2012 09:15 AM
Front or rear of vehicle?
2-door or 4-door?
Rottidog 08-25-2012 09:35 AM
4wd, 2wd?
Could be a door bushing, heat shield for the exhaust, cat rattling etc etc.
We need more info other than a rattle somewhere.
If it's a duller sound & sounds like it's coming from under the dash I'd take a small rag, fold it over a few times & put it between the hood & weather seal by the hinge on the side it seems to be coming from. If the sound goes away you need to get new conical washers for the hood & replace them.
step66 08-25-2012 03:30 PM
I'd be interested in the response as I have a similar issue on my 97: right side rear.
Kind of a musical:ting ta ting. Already checked (by hand) the stabalizer and shocks. I know I wlll not be able to replicate the noise in my driveway,but all the bushings look servicable and have no noticable play. It does not seem to be a rear bearing issue as it is consistant with suspension action....and no:the exhaust is not contacting any thing and is solid!
Let us know! Thanks in advance!
lionel2 08-26-2012 04:29 AM
Its a 4 dr. 4x4 and it sounds like from the rear. My guess would be some where from the exhaust. I have the stock pipes on there now. You think it might be the cat? Humm. I read somewhere when they go bad they make a rattling sound. Still looking under the car, found nothing yesterday, will look again.
Rottidog 08-26-2012 11:16 AM
Punch the cat from underneath & listen.
Have a friend hit the tail pipe while you're under it (wear safety glasses) & see it the exhaust hits something, like the rear axle or a hangers' rubber bushing is worn away.
lionel2 08-31-2012 08:48 PM
The rattle is gone all of a sudden. No worries now.
Rottidog 08-31-2012 09:26 PM
Sounds like the cat is getting plugged up & deteriorating. Any codes & not just the CEL but have it scanned to see if there are any impending codes.
