Rear Axle Code Help
Hey,
I need to replace both of my rear wheel bearings and can't figure out which part to order. I need to look at the code on the rear axle for either the "C" or "K" but can't seem to find the code anywhere on the axle. Any suggestions? Is there another place to look? Where is the code usually? I looked all up and down the axle, but don't have a lift right now to actually get up under it and look it down. |
you have to remove your brakes and take a look at the seal.
one is fitted inside(flush with the housing) the other has a lip on the outside of the housing. i just did my bearings last week and i just bought both seals (one was 10$ and the other 3$) and i bring back the one i did not use. |
| All times are GMT -5. The time now is 09:25 AM. |
