rear axle swap
rear axle swap
I have a 1999 blazier 4 w/d I broke a gear in the axle so i replaced the axle the gear ratio is the same gu6 was the code on the glove box. after i swaped axles out I have a vibration , so i jacked blazer back up and noticed that the drive shaft wobbles at axel end I know that there is 2 different types pf axles for that year 1 buffalo axel and the other i cant remember so I am thinking that the drive shaft dose not match the axle so my question is can iswap axle yoke out and that woulds take care of it or will the match
RE: rear axle swap
Have you tried rotating the driveshaft 90 degrees and reinstalling it? Give that a shot first.
RE: rear axle swap
ok i will try that real quick
RE: rear axle swap
okwell that seemed to help still have a small vibration at 55mph but that could be the tiers thanks for the help
blajeans
01-09-2013 12:58 PM
jmaynard
07-12-2011 01:03 PM
