Rear Brake Caliper Brackets
Does anyone know if they come with the slider pins and little metal clips for the pads? Mine was making an awful noise and when I removed it the pads and caliper bracket fell to the ground. I noticed that the metal clips that hold the pads in place were destroyed and I don't know how they were holding the pad there at all.
When I put new rotors and pads the clips looked good, I greased the slider pins and they worked fine but now the bracket is destroyed and I don't know why. I don't want to use the old slider pins anymore and I'm hoping they come with the new bracket or if you have to purchase them separately?
The brackets do not come anything else... You'll need new pins, boots, some caliper grease, and the new brackets. The new pads should come with new metal clips.
One thing that I would recommend is a good coating of rustoleum paint to keep the bracket from rusting and keeping it great looking for a long time!
Here a thread I made awhile back when I replaced the rear brakes on my old 2000 Bravada --> CLICK HERE
Just had to replace rear calipers on my daughter's '98 Blazer. The NAPA remans came with brackets and all HW (pins, boots, etc.) for $40 per side. Just something to keep in mind when checking price/availability.
quinn1991
Tires and Wheels
Dec 28, 2008 02:41 AM
