-   -   rear brake not bleeding (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/rear-brake-not-bleeding-85332/)
yuri39 04-12-2014 09:17 AM
hi i had a line leak to the rear brakes but i put new line from the front to the back all new now i cant get fluid to the back bleed the line but nothing. i want to try something out but i want 2nd opinion on it i have spliter on should i open it and see if fluid comes out from it or just let it sit with gravity pull or get something to suck the fluid from the back.:icon_shrug:
Captain Hook 04-12-2014 11:14 AM
If it's 98 or newer, and the master cylinder ran dry, you'll need an ABS capable scan tool to perform the automated bleed. That's the only way to get all of the air out of the EBCM. After the automated bleed is complete, gravity bleed each wheel seperately, and DON'T pump the pedal.
yuri39 04-13-2014 04:07 PM
no it's 4/97
