rear breaks
Just did my rear breaks they were really bad. new rotors and pads but now the inside pad is dragging seems to be stuck on. I can smell it. I used lube. I put at least 75 miles on them thinking they would break in but still stuck. Anybody have any idea whats wrong
2000 4x4x4 |
Sounds like something isn't put together right like your emergency brake lever, I would take it apart again and look.
Figured it out the caliper bracket slide pin was seized so i beat the pin out and bought a new one. that seems to remedy the issue
Common problem for some reason. I learned the hard way first time I changed out pads. Now I make sure to clean and lube the slide pins before reinstalling.
