Rear Caliper torque specs
Old Mar 10, 2017 | 08:05 AM
1999Blazerguy's Avatar
1999Blazerguy is on a distinguished road
Default Rear Caliper torque specs
Going to replace Rear calipers on my 1999 Blazer LT 4WD. Can someone please help me with the torque specs for this repair? I am most concerned with the banjo bolt, don't want to over tighten that one. I know the specs on the wheels already. thank you in advance for your help with this.
Old Mar 10, 2017 | 09:47 AM
rexmburns's Avatar
Super Moderator
I usually just go hand tight plus about a 1/4 turn but I've got a pretty good feel with a wrench. You have to be careful and not to over torque them because they are hollow and will break very easily if too tight. I always air on the side of not tight enough then if they leak it's way easier to snug them up a bit then it is to dig out a broken bolt!!
Old Mar 11, 2017 | 05:23 PM
porkfriedrice's Avatar
porkfriedrice is on a distinguished road
These are for my 03, but I'm guessing it's the same for your 99
Fastener Tightening Specifications
<- Back Forward -> Document ID# 774919
2003 Chevrolet Blazer - 4WD Print
Application
Specification
Metric English
ABS Sensor Wire 17 N·m 13 lb ft
Bleeder Valve (Front Wheel) 12 N·m 110 lb in
Bleeder Valve (Rear Wheel) 12 N·m 110 lb in
Brake Hose Fitting Bolt (Rear Wheel) 54 N·m 40 lb ft
Caliper Bracket to Knuckle Mounting Bolt (Dual Piston Front Caliper) 180 N·m 133 lb ft
Caliper Bracket to Mounting Plate Bolt (Rear Wheel) 70 N·m 52 lb ft
Caliper Guide Pin Mounting Bolt (Dual Piston Front Caliper) 115 N·m 85 lb ft
Caliper Mounting Bolt (2 Wheel Disc Brakes) 51 N·m 38 lb ft
Front Flex Hose Bolt (Front Wheel) 54 N·m 40 lb ft
Guide Pin Bolt (Rear Caliper) 31 N·m 23 lb ft
Mounting Brake Nut (Rear Wheel) 65 N·m 47 lb ft
Park Brake Cable Adjusting Nut 3.5 N·m 31 lb in
Rear Brake Backing Plate Mounting Bolts 65 N·m 48 lb ft
Old Mar 12, 2017 | 12:31 PM
thank you porkfriedrice, appreciate the torque specs.
Old Mar 12, 2017 | 12:42 PM
one more question. received both remanufactured brake calipers. they are both identical. they came in boxes with different part numbers. Are they reversible? Looks like only the bleeder valve will be affected. one will face forward one will face aft. Am I missing something else? Don't want to start this if I have wrong parts. Thank you in advance for your help.
Old Mar 12, 2017 | 02:26 PM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
They should both point to the rear and should be mirror images. Sounds like you received two of the same side;(.
Old Mar 19, 2017 | 07:55 PM
Got the correct caliper for the driver side, glad I did.
Repair went smooth, working perfectly now.
Thanks for all the advice.
Signed up for ALLDATAdiy, so shouldn't have to ask for any more torque specs...
jimspahr@msn.com
16
Jul 2, 2022 07:46 PM
cbash1979
Apr 6, 2008 06:00 PM
Goatmanof70
Oct 12, 2007 05:56 PM
1996blazer
Sep 23, 2006 07:04 PM
pontiacsouth
Jun 30, 2006 03:40 AM
