Community
Search
Rear diff help
Old 09-25-2013, 08:55 PM
wheeliemay is on a distinguished road
Default Rear diff help
Hey everybody...I was getting ready to pull the rear diff cover and lube but I noticed there may be a leak coming from the drivers side of the diff. What do you think?
Old 09-25-2013, 09:45 PM
rexmburns's Avatar
Super Moderator
rexmburns has a spectacular aura aboutrexmburns has a spectacular aura aboutrexmburns has a spectacular aura about
That's not uncommon. Get a new cover for it. I paid less than $20 for mine at Advance. It will come with a new gasket and you will be good to go.
Old 09-25-2013, 10:01 PM
Thanks, I didn't even think about a new cover So no worries on the side of the diff?
Old 09-25-2013, 10:35 PM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
meh i wouldnt worry about it.
Just get a new cover. there is 2 covers,one for a 7.5 and the 8.5. chances are u have the 7.5. hit up autozone etc. have em order both. then see if you can take em outside and compare.
Old 09-26-2013, 10:03 PM
AfterBurn99 is on a distinguished road
That's just up-splash from the gasket leak.
DO NOT USE A NEW GASKET. Use Black RTV Silicone and bead it around the diff cover. Be sure the surface is clean on both sides, and all old gasket material is gone. If you suspect that your diff cover is bent, you can straighten it with a small hammer, and a flat surface.
Old 09-27-2013, 06:38 AM
dpmeeks is on a distinguished road
Just did this yesterday on mine, I used the black RTV, no more leaks
Old 09-27-2013, 07:25 AM
rexmburns's Avatar
Super Moderator
I'm not saying anything is wrong with rtv (I've used it in the past myself) but please explain WHY NOT TO UsE A NEW GASKET! If you properly clean the surfaces, use a new cover, and torque it to spec in an even alternating pattern a gasket will work just fine.
Old 09-27-2013, 08:20 AM
chris015's Avatar
i always used a gasket,with a paper thin coating of rtv on each side. never had a leak.
Old 09-27-2013, 09:50 AM
@Rex, GM recommends using the RTV, and not a gasket. Paper gaskets will heat up over time, and dry, and then crack.
Old 09-27-2013, 10:33 AM
rexmburns's Avatar
Super Moderator
Interesting! Well I guess we shall see how my new paper gasket holds up I guess. I've used them several times in the past with no issues so I'm still ok with them lol.
Quick Reply: Rear diff help
