-   -   Rear hatch (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/rear-hatch-71526/)
scottytink Jun 17, 2012 09:45 PM
Rear hatch
Rear hatch won't open, it makes all the sound of working, and with either the button on the dash or the one on my keyless entry, it won't open. Any ideas?
247monster Jun 17, 2012 10:34 PM
you talking about the glass or the whole hatch?
scottl1346 Jun 18, 2012 07:19 PM
mines doing the same thing it just broke today i push the button and i cant lift the glass
scottytink Jun 18, 2012 07:50 PM
Well, I got mine fixed. if you have a jimmy like mine with the glass and tailgate seperate. take the screws off of the handle. pull the middle of the back panel and hit the switch to pop the glass manually. after that pull the rest of the screws off of the panel, one on each side of the gate once its down, and one where the glass locks in. then take a 9/32 socket and rachet and pull the back skin off, check the back panel to see if the little blue arm is working properly. youll hear the actuator make the noise and either way it will still work if the blue arm is or isnt working. if thats all fixed. the tailgate pop might get stuck which wont allow to glass to open properly. reset and double check that is is working properly. no parts. just about 30 mins of time.
scottl1346 Jun 18, 2012 09:20 PM
got it fixed drilled a hole in the blue arm and zip tied them together not tightly loose so it can pivot and it worked great
