-   -   Rear hatch wont "pop" (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/rear-hatch-wont-%22pop%22-27382/)
002dblazer 02-09-2009 08:02 AM
I just bought my 2000 2Dr last week and the hatch worked perfect, but as of last night it wont work and doesnt make a sound.
If i push the "pop" inside it doesnt do anything but if i hit the "pop" on my key fob. the lights flicker but still no sound. (no solinoid noise)
Aswell the interior lock/unlock wont work. but on the key fob. they work normal....
It sounds like a blew a fuse or something but i couldnt find a blown one.....
any suggestions would be great!
Thanks inadvance.
002dblazer 02-09-2009 10:11 AM
RE: Rear hatch wont "pop"
Update**
I just went and checked all the fuses in the 2 panels, beside the steering colum and under the hood... all fuses were fine!
is there another box im missing???
Does anyone have a wiring diagram for my truck so i can trace some wires???
Loxias209 02-10-2009 05:52 PM
Just had the same exact problem in our 97 the other day. Turned out to be the horn fuse that was the problem.
gdoak75 02-11-2009 11:27 AM
I have 2002 Blazer. The rear window won't unlock via the remote or the unlock button. The Dealership is quoting around $200 to fix the latch. Wondering if anyone has repaired the problem? Looks like the back tailgate panel will obiously need to be removed. Is there somewhere on the internet for instructions how to instructions?
002dblazer 02-11-2009 03:45 PM
I replaced the horn fuse and... nothing! tried a couple different ones and still nothing....
anyother suggestions or ppl had the same issue?
(it was the square horn fuse under the hood right?)
Loxias209 02-11-2009 04:50 PM
No, in the regular fuse box (the one inside on the drivers side) there should be a fuse labeled "horn". It's a 15amp fuse in mine. We replaced it becuase our horn stopped working, and were assuming the rear hatch was a whole other problem. Turns out, replace that one fuse fixed both problems.
002dblazer 02-11-2009 05:09 PM
oh ok ill take a look but my horn still works...
so im assuming thats not the issue....
Thanks
rhs856 04-21-2009 08:35 PM
I had a similar problem with my Blazer. It turned out that a plastic piece that connected the motor in the back to the latch broke. I had to break the interior cover of the tailgate off to manually open the window, and then I replaced the plastic piece with a bent coat hanger.
Indianarocker 05-27-2009 05:27 PM
The frickin horn fuse. Yep that fixed it. Im gonna make this site my homepage before its all over with
richiekeystone 08-05-2009 03:39 PM
98 blazer opened rear hatch manually
had the same prob ya'll are having with the rear hatch. You can pull the interior panel away enough in the center to get your hand in there. If u look down in there u will see a small rectangular opening cut out. Reach in there and you will feel a flat piece, push it down and the glass will release. Whoooooooooooo Hooooooooo. This brightened my day I tell ya.
