rear hatch would not open
I think I might see the very top of the gold lever you're probably talking about, but from the access point it's just a round head and no way to push left or right. Could it have rolled downwards and what I see is the "bottom" of the lever?
That lever arm shown in the picture above next to the broken blue piece actually hits another arm connected to the window latch.
Your gold arm may be pushed towards the driver side more. A piece of coat hanger may help in getting it back over to where you can get at it with a screw driver.
Something I found just today while trying to find out why mine was blowing fuses was on a 97 it's #2 fuse on the end of the dashboard and the darn cigarette lighter had a short in it. The courtesy light fuse has the horn relay, cigarette lighter, dome lights and the rear hatch together with it. The horn relay was not indicated in any of the manuals I found.
To find the short I jumped accross the fuse with a light bulb to give it a load to burn off and disconnected parts that were in the circut until the light went dim and the horn relay started buzzing. On my second try I moved the lighter socket and the light bulb went dim. Found it. My rear hatch and dome lights work again.
Sorry I never got back on here to give an update, but the hanger worked like a charm. Thank you very much Swartlkk. I really didn't like my chances trying to get the arm to swing up with a hanger in that tight spot, but it worked perfectly. I have been too lazy to replace the actuator, but at least I'm able to reach the lever from the back seat and open the hatch on the few times that I do need to get in there
