Rear Right Blinker working but Front right does not HELP! I have searched....
Iam having a blinker issue on my 2001 SLT. The front passanger side markerand main frontblinker does not work (the bulbsdowork during normallighting condition). The back one works fine with no problems other than the Hyperflash that is enguaged. The blinker does not work during hazard operation either. I have replaced the bulb.Also thesignal in the dash cluster works properly. Can anyone help. Thanks!
You have a bad ground, check behind the radiator core support, near the air box. The should be a ground wire in that area for the lights from the wire harness...
kool i will check that out....that is what i was hoping to hear.....have you had this same problem before?
also can you be a lil more detailed on where to look for the ground.....i am having a hard time finding it.
blazintexas
05-01-2012 06:01 AM
blazerJim1701
06-15-2010 09:16 PM
fijianrocket
02-02-2010 10:07 PM
