Rear seat
What is the best way to remove the rear seat behind the driver?
Should just be a couple of stud nuts and of course the plastic covers, right? |
3-4 18mm nuts... juts swapped mine out a week or two ago... theres also the support, I removed the one 10mm bolt that goes to the seat, or you can do the 18mm bolt on the floor
Cool, Thank you
Just remember you need to put the bolts back in the middle where the buckle is, to hold down the seat behind ththe driver
Do you have to take both seats 60/40 or can you do just one?
You can take the 40 completely out and leave the 60, but you wont be able to use the 40 without the 60. Because the seatbelt buckles are mounted to the 60 portion of the seat. You will see what I mean when you remove your seat.
I want to take out the 60, but it looks like it shares bolts with the 40
The seat buckle for the 40 portion is also mounted to the 60 portion of the seat, so you wont br able to use the passenger side seat belt...
The seats use the same bolts, but have separate seat brackets
Thank you guys, I appreciate the help
