-   -   Rear view Mirror mounting (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/rear-view-mirror-mounting-45245/)
Fusefinder 06-02-2010 08:50 AM
What will be the best holding and least messy way to remount the rear view mirror?
Thanks.
vanaman 06-02-2010 08:58 AM
Go to the auto store and buy epoxy specifically made for re-glueing your mirror to the windshield. The directions says to use one drop of epoxy, but I use 2 and have had no problems.
Fusefinder 06-02-2010 09:08 AM
Thanks I was going there today and ask, but it’s always nice to ask someone who has actually done that already.
chevie2 10-15-2010 09:48 AM
Can you glue the mirror back on if you cannot get the mount separated from the mirror?
Frank
dimone545 10-15-2010 11:56 AM
yes there should be no reason why you couldnt
vanaman 10-22-2010 05:01 PM
No, the mirror will be too heavy if you try and glue the mount onto the windshield with the mirror still attached. Get a pair of pliers and pull the mount free of the mirror. File down the mount a little (but not too much or the mirror will vibrate-don't ask how I know) and attach it to the windshield. After the glue dries, install the mirror into the filed down mount. The mirror should now install easily. If the instructions tells you to use one drop of glue, go ahead and use 2, (there's plenty of space available for 2 seperate drops) if you don't the mirror will eventually drop off again.
