replace powered door with manual door
So I have an 01 4-door blazer. Its blue with a red door. I have all power but the colors do not match. So I found a blue door from a 98 blazer that matches, but it isn't equipped with power options. I should be able to do any work involved but wanted to make sure that it is even possible and that everything will match. Can anyone give me a definite yes that the switch will go smoothly?
Originally Posted by firstblazer
(Post 503283)
but wanted to make sure that it is even possible }{ and that everything will match. Can anyone give me a definite yes that the switch will go smoothly? But on to the solution. You're going to have to pull the door panel, I assume on yours If there is a hole where the window crank can go, then its probable that the inner door is the same on both |
| All times are GMT -5. The time now is 04:46 AM. |
