replacing the abs senser
Old Aug 25, 2013 | 04:42 PM
patster's Avatar
patster is on a distinguished road
Default replacing the abs senser
I have a 1996 blazer, automatic 4 by 4 and i need to replace the abs senser and i have no idea and dont want to take it to a mechanic(if i dont need to) Is there a easy way to replace.
Old Aug 25, 2013 | 06:23 PM
AJBert's Avatar
If memory serves correctly, a single allen head bolt and a plug. Not sure if you have to pull the rotor or even if you have to pull the hub to replace it.
I'll find out soon enough when I get off my butt to do it myself.
Old Aug 26, 2013 | 12:06 AM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
If the 96 is like my 98, then you do have to take the rotor off which means pulling the caliper and bracket. It's really not too bad.
Old Aug 30, 2013 | 11:00 PM
Jaylo's Avatar
Jaylo is on a distinguished road
There is also an abs sensor on transfer case. But it appears ur talking abt wheel sensors.
Old Aug 31, 2013 | 01:16 AM
abig84's Avatar
the only problem i ever ran into messing with them is sometimes you get rust above the o-ring where it goes into the bearing and the sensor breaks off in the bearing. which really doesnt matter since you are replacing it but you will have to dig out that plastic piece
porkfriedrice
27
Jul 6, 2012 08:03 PM
Tinted
Mar 15, 2012 02:56 PM
iamchevyman5
Feb 28, 2011 04:35 PM
stormshadow1
Apr 23, 2009 09:46 AM
chevyrocksu
Headers, Intake, & Exhaust
Nov 15, 2006 10:44 AM
