Replacing A/C Low Pressure Switch- 2000 Blazer
Can you replace the switch without replacing the freon? I thought there was a valve that let you replace the switch, but a friend of mine said I would have to recharge the system.
You can replace the low pressure switch with the system charged. There is a check valve in the connection. The high pressure switch is a different story.
| All times are GMT -5. The time now is 02:38 AM. |
