Reverse Turn Clunk
I'm hoping it's the hub. I've changed wheel hubs on other vehicles before and they're much easier than what I've heard about the UCA bushings.
So how do I check the hub? I've changed them out when they're making whining noises or getting hot but as far as I know these hubs aren't doing either of those things.
To be honest, I dont exactly know how to check them. I experienced the same problem as you a couple years back, after literally changing every front end part, I still had that damn pop/clunk noise every time I had the wheels turned while backing up. Finally someone said it might be the hubs. I figured, god I hope so, as there is nothing else to change, lol. Sure enough, after that the noise was gone. I think it takes a lot of torque to get them to pop, which is why you cant tell by just wiggling the wheel while the vehicle is jacked up, like you could do with some other front end parts. Just my 2 cents.
I suggest you stop throwing money at it in parts and have a mechanic you trust look into the problem. To me, it sounds like it's the control arm bushings, bit I'm not there. If it is, do yourself a favor and replace them with poly ones not rubber.
My first suspicion was the axles because I had just replaced the ball joints, tie rod ends, and idler arm. I had the truck at Graham Auto after I replaced everything and Rick never said anything about the control arm bushings and he's really good at double-checking my work.
For now I'm going to wait and do some more research and see what else I can find out.
Its not difficult to tell if your upper control arm bushings are bad.Look under the hood or through the fenderwell and look at the rubber bushings on the back of control arm.If the rubber is detroriated then you need to change them.Your also going to have to undo the upper balljoint with may damge it in the process.Thats why I suggest just replace the whole A arms if thats your problem.You can get them at Rock auto very reasonable.While the maybe difficult its not impossible.With a little patiance it can be done.I would look at the lower control arms.I think thats where in your problem is.I have had the same problem before on other vehicles i owned.
If they are bad let your trusted mechanic do the job.Because of tortion bad suspension your going to bite of more than you do.I have done but it took 3 people.
PS if you need a set of control arms let me know I have a brand new set that we maybe able to work something out on.
