-   -   Rough engine with P0300 code (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/rough-engine-p0300-code-80450/)
palmer96 Jul 15, 2013 08:19 PM
Running rough, even more when you put it in drive. Did full tune up. Pulled the plugs today, and #3 and #5 were burnt/black. Thinking either head gasket or spider, any thoughts?
Toby Hanson Jul 16, 2013 02:12 AM
I would do a compression test to see what the compression is all around the motor. I would also pull the plenum and look for evidence of washing from leaking fuel. A fuel pressure and leakdown test is also a very good idea. With all of those tests you should be able to find what the problem is and get pointed toward a fix.
palmer96 Jul 16, 2013 07:28 PM
Finally got my hands on a compression tester. i only got one side checked. hoping to do the other side tomorrow. Got about 60 lbs in #3 and #5 cyl, but had over 100 lbs in #1. Im thinking its head gaskets. hopefully the head aint cracked.
AndrewO1991 Jul 16, 2013 07:54 PM
still do a fuel pressure and leakdown test.
palmer96 Jul 16, 2013 08:40 PM
I already did a fuel pressure check and it holds strong at like 56-58 psi. I don't have a leak down tester. I will ask around to see if I can borrow one though.
