Seafoam/Lucas questions
If the lifter tick goes away quickly after warm-up, especially on cold mornings, Id say youre ok. Remember, youre using a multi-viscosity oil that takes time to warm up and get "light" enough to travel through all the oil passages.
Some might recommend you switch to a heavier oil, but I always say you cant cover up a problem like that with a something in a bottle.
If the tick persists, you may have worn lifters or cam lobes. Time to call up Comp Cams and get something badass.
my best guess is that your lifters/lifter bores are a little worn out, and the lifters are losing oil overnight. not uncommon, and short of swapping them out, theres really not much you can do about it. the oil is just leaking back down into the pan from the lifters, and it takes a few seconds for them to pump back up when you start the engine.
I have a Master Mech who lives up the street from me who just might disagree with the R.P. God statement. He has a 600+ Hp Camaro that he races and use to use R.P. in it and his oil pressure bottom out. He thought he had blown the crank again. He would run the car up and down the street here and do a burn out or 2, he thought what the heck the crank is gone. Well, it wouldn't go..so he said self lets change the oil, so he dump the R.P. and but in Mobil, fire her up and why I be dog gone, his oil pressure was fine!!! His crank was fine. The R.P. in the Oil Dump pan look very thick and very black (keep in mind he races cars, so he changes his oil very, very often due to the heat the engines build up). It might work great on reg cars and trucks, if you want to pay the price..but no good for high perforance cars as it says it is.
I agree with Kyle pretty much. I'm an old retired mechanic. I have never lost an engine due to the type of oil or filter I ran.
I run NAPA synthetic with AC Delco, NAPA, Super Tech filters. I change my oil & filter every 10,000 miles with synthetic. I change Dino oil & filter every 5000 miles. I ran a 79 Chevy CK25 4x4 350 to over 300,000 miles with only replacing a timing chain. The rest of the engine was never touched except for regular maintenance items. I have almost 200,000 on my 86 F250 4x4 460. I have ran several others 100,000+ miles & never had and engine failure because of oil. Never blew up an engine & I have been using this schedule in oil & filters for 40 years.
I use Lucas or Power Punch with my oil changes on older engines. On any vehicles we have bought new & run straight oil. After 100,000+ miles I might add the additives. I like LUBEGARD for auto trannys.
Just out of curiousity, do I ever have to replace the timing chain? I have already had to have the intake gaskets replaced at 72k. Other than that, this engine has not been apart for anything. The only additive I use is Lucas. A few years ago, someone (idiot who will remain nameless) I know put stop leak in it because of the oil cooler hoses. I just had both of them replaced. The filter to engine ones in summer 08 and the other ones in October 09.
For the tranny, I had them put the Lucas stuff in it just as a preventative measure. I also have a B&M trans cooler. THAT was a tight fit. I bought the largest one I thought could fit on eBay The shop had to mount it with the fittings pointed down and cut the return pipe near the oil filter and attach the hoses to the cut pipe and the radiator. The transmission guy thought I was crazy to get a cooler put in because I don't plow or tow with it.
Oh, and make sure you get a good quality oil filter WITH A BYPASS VALVE. Im surprised how many people still dont know about oil filter bypass valves. Fram and the like, generally dont have one. Napa GOLD, and anything made by Wix has a valve. Interestingly enough, Super Tech (walmart brand) has a bypass valve, and is usually the least expensive.
ComputerNerdBD
02-09-2010 05:05 PM
cide
11-07-2009 01:26 PM
ComputerNerdBD
10-17-2009 04:46 PM
