-   -   security light/ occasional no start (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/security-light-occasional-no-start-89923/)
newguy 05-26-2015 04:07 PM
Started a few days ago. 2000 zr2. Sat.stopped at the store, came out no start. Turned over, fired then died. After 10 minutes or so started right up. Same today, went to store came out no start. Waited and it started. Thought maybe Ign. module getting hot so I replaced that.
Started it up, security light was on and stayed on. Shut it off, restarted and no light. Any ideas? ign. switch maybe?
Captain Hook 05-26-2015 07:52 PM
If the security light stays on, you're looking at a Passlock issue. Passlock will allow the start but the BCM will command the PCM to shut off the injectors and it will stall within a very few seconds. Could be a communication problem or the sensor is not recognizing the key. Need to read the body codes, (powertrain scanner will not access them).
newguy 05-26-2015 08:03 PM
so how do I read them?
Captain Hook 05-26-2015 08:32 PM
Need to find someone with a high dollar scanner that can access them.
newguy 05-27-2015 09:32 AM
Captain, I bought a new cylinder, Installed it and nothing, wouldnt even turn over, no security light but everything else worked. Was hearing a clicking from under the dash( picture on another post) pulled the panels and found a viper system. Unplugged the longest connecter which had a fuse inline and the clicking stopped. Turned the key and she fired right up. Let it run for 20 minute or so, shut it off and restarted. Security lights seem normal. Thinking the viper was the problem all a long, Fingers crossed. Will report back in a few days
Captain Hook 05-27-2015 09:39 AM
Cool! Good job. Aftermarket security systems don't get along very well with Passlock. Basically people install them to get the key FOB so they have keyless entry and or remote start. Passlock is way more sophisticated than any aftermarket system. The lock cylinder is not what "reads" the key. There is a sensor further inside the lock cylinder opening.
newguy 05-27-2015 11:27 AM
What have I learned? Hate car alarms, always have, always will
madmaxxed 05-27-2015 12:13 PM
I hope i'm not hijacking this thread but have either of you seen a GM security feature where you must click left directional before turning the key otherwise the horn honks with no start? The elderly, one owner, I bough my blazer from said he had it from the factory.
newguy 05-27-2015 12:23 PM
Now thats funny, yours does this?
Captain Hook 05-27-2015 01:03 PM
Newguy, lesson learned, A+
Madmaxxed, Something wrong there. If it has an aftermarket security or remote start system, it's very likely that's the problem. Might want to remove it before it causes a more serious issue;)
When I see or hear an alarm going off, my standard reply is, "Buy a house in a good neighborhood, and you wouldn't need that thing". ;)
