| Brian5792 |
Dec 23, 2012 11:13 AM |
Service Engine Soon: Tranny Code ?
Just bought a 98 Blazer LT (146K mi) from a private seller. It runs & drives OK after new ball joints. My shop gets 2 codes from the diag. computer. One is "Fuel Injection" which he suspects is the Spider Fuel Injector ($650-700). Not sure about this since the recpts that came with it show fuel injctr work back in May '11. The other code is "Transmission". I have read several posts regarding trans but their problems aren't similar. In fact, it shifts fine! The only thing that may be related to the trans is a vibration that happens when stopped at a red lite. It ranges from "mild" to "worse". Whan at its worst, the sun visors shake and there is some thumping noise. You'd think the engine is mis-firing & threatening to stall but the rpms remain at a steady 600 or so. Shifting to Neutral doesn't help. Giving it a bit more gas and keeping my foot on the brake helps a little. The shaking stops (or becomes unnoticable?) as soon as you pull away. Its as if some driveline component that is supposed to spin in a tight spiral is not doing so at idle. If any other members have had, and solved (!), a similar problem, please respond. Thanks!
