-   -   SES Code P0452 (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/ses-code-p0452-71446/)
O-man21 Jun 14, 2012 11:27 AM
SES Code P0452
O'Reilly had a ton of possible causes listed, how do I go about fixing this?
Truck still drives fine.
swartlkk Jun 14, 2012 12:33 PM
Here is a link to the trouble code which will walk you through the process of trouble shooting the code from start to finish and should identify the problem:
P0452 - Evaporative Emission Control System Pressure Sensor Low Input
As well as a link that will show you the threads where others have posted about this same code --> Search for "P0452"
O-man21 Jun 14, 2012 01:56 PM
Thanks for those. I read them over and looked through the search results, and honestly, a lot of it went over my head. I am pretty mechanically inclined but I have limited access to tools and only know the location of major parts in an engine bay.
Is there a common problem that causes this code? Or since I don't have many tools, should I just break down and take it somewhere to fix?
Also, is this something that needs to be fixed ASAP? I'm starting a new job next Wednesday, and moving between now and then, so if I could use the truck until after then it would be awesome.
Thanks!
O-man21 Jun 14, 2012 07:32 PM
driving around today, light went off for about 2 hours. Turned it on after a brief stop and it came back on. Any reason that would happen?
