shifter cable adjustment
so i have my 99 blazer column shifter how do i adjust the cable it is just a tad off from going in park it almost goes in but dosent so it read it in revers i can put it in park under the truck i have had to do it in bad parking lots a few times e brake only holds so much
Type (or copy/paste) "shift+cable+adjustment" into the search feature and you should find the info.
ahh i didnt do the +s earlyer thanks man
Yeah, the + links the words together making it necessary for all 3 to be in a post/thread. If you just put it in with spaces, it will return all posts/threads with those terms individually (many more results). To constrain it more, you can do an exact term by putting quotes around the term using spaces between words. That can artificially restrict the results though.
The 'Search Guidelines' link in my signature runs through the Boolean search options. |
