Shuttering while trying to accelerate
Old 07-13-2009, 11:38 PM
matclark's Avatar
matclark is an unknown quantity at this point
ok,,tonight i was on the highway, going up a steep hill, and as soon as i crested it, and let off the throttle peddle,it back fired through the intake really bad,,but then it drove good for about 10 miles or so, up and down hill, it started sputtering again coming down a hill with a real long straight stretch, i was just barely touching the throttle peddle. tomorrow i am going to clean out the distributor, and check and clean the cps and reluctor ring, and re-clean the maf, and check out the map....i will let you know tomorrow evening what i found out
Old 07-14-2009, 06:34 PM
notime1963's Avatar
notime1963 is on a distinguished road
Here is where i am in trying to solve this issue. When i unplug the MAP sensor and drive there is no shuttering, missing or anything. If i unplug the MAF senosr and the MAP sensor it misses and shutters bad. With the MAP sensor plugged in and the MAF sensor unplugged it misses and shutters. I did clean the MAF sensor just to make sure it was not dirt causing the problem. I don't know if my MAP is bad and that is why i am having issues or what. I am going to replace the MAP sensor and see if it works after that. I wish i were better at checking voltages, but i am not sure how to do it with the MAP sensor plugged in. I will let you know if replacing the MAP works for me.
Old 07-14-2009, 10:48 PM
matclark's Avatar
didnt fix a thing !! still broke !!
cleaned/inspected and checked all voltages for map, tps, maf,,checked the power to distributor, and coil input/output, everything checked out fine,,,rechecked and cleaned all grounds,,,tomorrow i am going to check the fire at the plug, i have an inline gm spark check tool,,,,so i guess i will post tomorrow,,,the saga continues...lol
Old 07-14-2009, 10:53 PM
reelbroke2's Avatar
reelbroke2 is on a distinguished road
when was the last time you did a tune up? Plugs cap rotor wires fuel filter air filter? save yourself some grief and buy Ac Delco!
Old 07-15-2009, 11:42 AM
matclark's Avatar
2 weeks ago, today,,and yes, all ac delco from the dealership...
Old 07-15-2009, 12:41 PM
GreggieAtTheBat's Avatar
GreggieAtTheBat is on a distinguished road
Default Sounds familiar
Changing cap/rotor/wires/plugs is good; check also the ignition module.
I chased these symptoms (no ecu code though) for two years on my g/f's '95. Saw that EGR and IAC valves kept getting clogged with carbon, finally my neighborhood mechanic tested the ignition output and the voltage was way low.
~$35 part fixed the problem (after I spent ~$200 on multiple IAC and EGR valves). Worth checking, at least.
Old 07-26-2009, 08:52 PM
matclark's Avatar
my icm checked out fine....
Old 07-26-2009, 09:53 PM
aaron96gmc's Avatar
aaron96gmc is on a distinguished road
Mine did the same thing, but i have found the problem. I cleaned the maf sensor, and the egr valve and the grounds. i have also put in new spark plugs ac delco rapid fires gapped at 0.35 gap and that was the end of the po300 code. i guess these motors like hotter spark. Its runs great now. give it a try it will posibly fix yours too. I have taken mine about 500 miles so far sience and no problems
melstal
10-11-2014 11:34 PM
Gtvfd4
03-24-2014 04:37 PM
matmanrocksu
08-14-2011 11:46 AM
warthogdriver
05-30-2011 10:09 AM
xderkax
03-23-2010 06:29 AM
Quick Reply: Shuttering while trying to accelerate
