-   -   Side vew mirror. (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/side-vew-mirror-236/)
TwilightEpitaph 12-14-2004 05:04 AM
Side vew mirror.
So my side view mirror fell down on my 96 blazer LS. Its an easy fix(got me some JB weld) but im not sure how to pull the door panel off so i can detach the wire for the mirror and remove it from the door for repair. I had to pull the door panel off on my last vehicle and ended up breaking some clips resulting in it never fitting right again. So this time i figured i would gain some knowlege on this before i go running in and mess everything up. all i need to know is if you have to pull it off a certain way or if you have to pull from the bottom and lift it up or what. thanks in advance.
blazin97 12-14-2004 09:09 PM
RE: Side vew mirror.
If you start at the bottom it comes off kinda easy, just take your time. The important thing is to take your time and be careful.
