Is this a sign of a bad coil =====>
Old Feb 23, 2009 | 07:05 PM
zombiewoof's Avatar
zombiewoof is an unknown quantity at this point
Default Is this a sign of a bad coil =====>
I opened my hood when it was dark out and reved the engine, I noticed a small blue ark at the side of the coil, Is this a normal thing or should I replace the coil? Thanks for any advice in advance...Lorne
Old Feb 23, 2009 | 07:14 PM
BlazinMike89's Avatar
BlazinMike89 is an unknown quantity at this point
Default RE: Is this a sign of a bad coil =====>
Coil itself, like the side casing of it? or the wire that goes to it, if its the first one then I would replace it, if its the second just change the wire from the coil to distrubutor
Old Feb 23, 2009 | 07:25 PM
zombiewoof's Avatar
Yea from the coil itself,,,,the side casing....Ive been having problems with a flashing check engine light...maybe its been the coil all along
Old Feb 23, 2009 | 07:28 PM
bandidolenny's Avatar
Is the coil cracked or broken? Try cleaning any dirt and grime off of the coil and check the coil wire to be seated correctly and the insulating boot to be in good condition. Otherwise,yea,I guess I would replace the coil too.
Old Feb 23, 2009 | 09:07 PM
It is definitely not normal for arcing from any of the ignition components. It definitely sounds like your coil housing is cracked.
While you are at it, take a small spray bottle with some clean water in it and mist down the rest of the system. Replace anything that has arcs jumping out of it.
blainenbecky
Mar 9, 2013 10:38 PM
Lancealot
Feb 22, 2011 07:34 AM
dundeeboy
Nov 9, 2010 05:54 PM
blazer92
May 9, 2010 02:28 PM
ghost
Sep 15, 2009 11:52 AM
