Sound coming from right side.
I have a 2000 Lt 4x4 blazer auto with 93,350 miles on it.
When I do a med to fast start (from a dead stop or kick it into passing gear) I hear this whistleing sound coming from what it appears to be behind the pass side kick panel. From what I can gather from reading other posts, that should be where a part of the 4x4 engagement is. (my 4x4 is acting up also, just blinks when I put it in auto, 4 lo or 4hi). Is there a vacuum hose behind that kick panel? |
There is a actuator under the battery that has a vacum line running to it that pulls it into 4 wheel drive .I would remove the battery and see if the vac line has a hole in it and see if actuator has vacum to it and if actuator moves when you put it into 4 wheel drive
| All times are GMT -5. The time now is 05:10 AM. |
