Originally Posted by Cimmerian
(Post 701037)
Man, you guys are lucky. I still can't even find a rear hatch tire carrier...
Maybe if you live in the rust belt, and cars are rusted in half in ten years, might make it hard to find one |
Originally Posted by cleburne red
(Post 701039)
I found mine in a pick n pull in about five minutes. Blazers are a dime a dozen in a junkyard, should be easy to find one!
Found 2 ZR2's in the Reno,NV pic-n-pull at the same time. Along with many other Blazers and s10's.
On the subject of tire carriers. For the external carrier on a 2001 ZR2, can the hinge be undone and the carrier removed without cutting/drilling/grinding the hinge pins? Mine is getting loose. I've added some notched washer for the up and down play but it seems it may need bushings for lateral play. If I can get it apart I may be able to use oversized hardened bolts. Don't see any way to get a wrench on it. |
Cimmerian, I could ship you one, but that might be a bit pricey.
I also plan on installing the 2 door carrier onto my 4 door. As far as it blocking a lot of the rear window, I plan on running a back up camera for assistance on that. I will be placing the camera in the old spare tire joist hole. But as for now, it sits flat in my trunk space. Pulled my subs last year, so between the spare and some tools...not a lot of space. Would love to cut the floor of the cargo area where the spare sat under, and make more space there....as it is just an empty void now. |
I got an external spare tire carrier last summer that I will likely install as my new larger tires won't fit under where the original spare is. (I do have an old tire there but I really would prefer a tire that matches the ones I have.)
One my my issues will be to see if I can swing the tire out of the way when I have either my utility trailer or boat trailer attached. |
(Post 701058)
(Post 701070)
[...] my new larger tires won't fit under where the original spare is.[...]
(Post 701070)
Originally Posted by Mike.308
(Post 701078)
I assume, hanging on the boat side as a bumper doesn't count? ;)
I pull my pop up trailer, sometimes I put my canoe (14') on the trailer. Without the canoe I dont have a problem. With it, it blocks it at about a 55° angle.
standard 235x75r15. I think it comes out to about 29"... edit: forgot to add your quote christine... |
(Post 701008)
I'm actually in the process of installing some off road lights, and one pair is going to go on the roof aimed backwards.
Its for backing up on a trail after dark, but if they "accidentally" get turned on when some bozo is tailgating... Oopsie |
