Spark plug question???? Plz help me
I did a search for OEM Spark Plugs. I found 41-993 AC DELCO as the right plug. But when I look up that number on Rockauto I can't find that number. I find Rapid Fire & a few others. There also seems that there could be an updated number?
Can someone tell me what spark plugs I should use in my 98 Blazer LT 4.3L I want to go with AC DELCO PLATINUM PLUGS. Because I believe some version of their platinum plugs are OEM.
Thanks in advance.
Thanks in advance.
Thanks I found it finally. What are the difference between the rapid fire & the OEM plugs besides a few dollars each?
I'll hope someone else chimes in with possible more info on the Rapid fire plug.
The older AC Delco 41-993 Professional Platinum plugs are double platinum plugs (platinum tips on the center electrode & ground strap to better resist spark erosion) that will last A LOT longer than the rapid fire plugs will. The rapid fire plugs are regular copper plugs that won't last nearly as long as the double platinum plugs in these high energy ignition system vehicles.
AC Delco has upgraded the 41-993 plugs to their Professional Iridium (platinum ground strap with an iridium center electrode) which is available through retailers with higher inventory turn-over rates. Iridium has all of the benefits of platinum in terms of resistance to spark erosion with an added benefit of being able to be manufactured to a finer tip diameter for better spark control.
IMO, you can't go wrong with either, but if you are going to pay $5+ per plug, make sure you get the iridium plugs.
Thanks again for the advise I will take it.
I ran a set almost 100K then sold our 97 Blazer & they are still going. I just installed a set of 41-993 AC DELCO plugs in our 98 Blazer 4x4. What was in there was a new set of cheap standard Autolites #605. The AC DELCO plugs have helped & seem to run better.
Did you have a miss or any idea that one plug was cracked? I'm assuming your referring to the porcelain part of the plug?
