spark plugs 2000 blazer
Old May 15, 2006 | 06:47 PM
geekdagr8's Avatar
geekdagr8 is an unknown quantity at this point
Default spark plugs 2000 blazer
im changing my spark plugs on my blazer this weekend...they look like a pain in the butt to get out...any tips on how i can get them out easier....thanks for the info
2000 chevy blazer 4 dr 4x4
95000 miles
Old May 15, 2006 | 09:03 PM
Jman's Avatar
Jman is an unknown quantity at this point
Default RE: spark plugs 2000 blazer
I just did my girlfriends plugs and I found that if you jack it up and do it through the wheel well it works pretty good. Also the drivers side middle plug(#3) is a pain, it will help alot if you undo the steering arm. Only 1 bolt and it slides apart and up out of the way, then its a piece of cake.
Old May 15, 2006 | 11:38 PM
96Ls4Dr's Avatar
96Ls4Dr is an unknown quantity at this point
I just did ours today. Jacked it up and took the wheel off. The rubber guard was already cut/torn apart so I didnt have too much trouble seeing. I barrowed a swivel sparkplug socket from a friend and it worked great. The passenger side was a piece of cake, the drivers side was easy too except the middle plug. I didn't remove the steering arm so I had a little bit of a tough time but not to bad. Just kinda took my time and slowly twisted it in by hand until I had enough room to put the swivel back on.
Old Mar 20, 2007 | 12:04 AM
philzentz's Avatar
philzentz is an unknown quantity at this point
Just bought a used 2000 Blazer w/ 32,000 original miles on it. Loaded and in perfect condition, but due for plenty of general maintenance. I joined this forum just for some ideas on how to get the #3 plug out. Been driving on five new plugs for a couple weeks now. Thanks for the ideas. Based on the reading some of the posts, none of the maintenance comes easy on this thing, so I'm glad to have a place to talk it over. Thanks again. Phil
Old May 16, 2007 | 12:18 AM
cdngearhead's Avatar
cdngearhead is an unknown quantity at this point
i cut off a cheap chinese extension and welded a 14 mm nut to it, worked great with a 14 mm wrench from the top with my "device" stuck into a plug socket
JavierEscalonJr
Oct 14, 2020 11:38 PM
toms2000blazer
Dec 20, 2015 07:23 PM
blazzer
Jun 4, 2013 04:40 PM
abe_f
Apr 1, 2013 11:19 PM
Yankee Team1020
23
Aug 3, 2011 08:05 AM
