speedometer pegged while parked
Old Apr 14, 2011 | 07:37 PM
abig84's Avatar
Default speedometer pegged while parked
98 bravada. this is the least of the trucks worries but its the one problem i really dont know anything about.
Old Apr 14, 2011 | 07:43 PM
Could be a problem with the cluster... Do you have access to a full feature scan tool? My Autoenginuity scanner can command positions of all of the gauges.
Old Apr 14, 2011 | 07:57 PM
abig84's Avatar
i was hoping it isnt the cluster, but hopefully not the computer. i really cant drive it yet to see if it would go away or reset. but yeah we got a obd2 genesis scanner at work that can pretty much do anything
Old Apr 14, 2011 | 07:59 PM
The scanner will also tell you if the VSS is providing the proper information to the PCM. The scanner would be my first stop.
Old Jun 18, 2011 | 04:47 PM
mrclark78's Avatar
mrclark78 is on a distinguished road
Did you end up fixing the issue? I am having the same issue on my 2002 Blazer, it happen after I replace the water pump and try to start it up
Old Jun 20, 2011 | 08:41 PM
abig84's Avatar
the truck pretty much fixed itself. it had a bunch of other more important issues that needed addressing first, after worked on it for a few weeks i got the engine together, started it up and it was fine. i did have the battery disconnected for a few weeks while i was fixing everything so maybe get lucky and it just needs a battery pull
Grandpaswagon
Mar 12, 2014 08:07 AM
spiderx
Dec 10, 2012 02:04 PM
joeewhite
Jun 26, 2010 08:43 PM
peters702
Jan 29, 2010 10:50 AM
Rottidog
Jul 20, 2009 12:05 PM
