-   -   squeeky breaks! (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/squeeky-breaks-43166/)
vrryder Apr 8, 2010 06:23 PM
squeeky breaks!
I have a 99 blazer 4x4. My breaks are hoibly squeaky, mostly when i hit the breaks but sometimes when i dont. I recently changed all break pads rear rotors and one rear caliper. The front rotors look good to me. Someone mentioned about springs in the break assembly????? What could be the problem?
1997 red blazer Apr 8, 2010 08:19 PM
How long ago did you do this BRAKES ? I no you said recently, A day ago,Week, Month ? Did you turn the Front rotors ? What type of BRAKE Pads did you put on the Blazer ? Sorry to Ask all the Questions, just trying to narrow the problem down some. T.J.
vrryder Apr 8, 2010 08:25 PM
the caliperand rear rotors are 2 months and the pads are less then one.
1997 red blazer Apr 8, 2010 08:49 PM
Ok, do you remember what type of pads ? Metallic, semi-metallic ? Sounds like maybe the pads have not seated to the Rotors ?
UrbanOffRoader Apr 8, 2010 08:55 PM
This is going to sound stupid, but check the caliper bolts. They can sometimes fall out if improperly tightened after a brake job, which will cause the caliper to drag slightly on the edge of the rotor. It'll sound alot like bad brakes.
Don't ask me how I learned this.
